Drag Racing Tech
How do I wire a start button and ignition switch
Old 09-26-2007, 08:51 PM
brandonppr's Avatar
Default How do I wire a start button and ignition switch
I have a Moroso switch panel with start and ignition.
I want to use it this way:
I want to just leave my key in the on position at the track and when I want to start it I want to just flip the ignition switch on and press start.
I know the how to wire the starter.
My question is how do I find the wire that needs to be switched that goes to the ignition?
I don't want anything to be on when the key is on until I turn on the ignition switch.
Car is 98 Camaro
Old 09-26-2007, 09:24 PM
BTLFEDSS's Avatar
Check the apprence section for push button start.Should tell you what you need to know
BTLFEDSS
Old 09-26-2007, 09:53 PM
brandonppr's Avatar
I know how to wire the starter button. I need to figure out the ignition switch thing.
