Fueling & Injection - ohms for fuel gauge?
View Full Version : ohms for fuel gauge?
Smoke_ur_5.0
06-04-2003, 12:21 PM
Needing to get an autometer fuel guage but don't know what the ohms are on it...anyone know?
Thanks!
NO CATZZ
06-04-2003, 12:34 PM
GM should be 0-90ohms.
94z28ls1
06-04-2003, 04:23 PM
How are you going to make it work I bought one too and don't know how to hook it up to make it read correctly. Mine is a fuel level guage
j240z
06-13-2005, 11:17 PM
Does this apply to all the plastic LS1 tanks too?
superchannelkev
07-18-2005, 11:35 AM
hey back from the dead here but I wanted to get a definate answer if the 0 -90 ohms is true for all ls1 vehicles before I go out and buy my gauge. Thanks guys!
jimmyp
09-05-2005, 06:27 PM
ttt again
Elite_Hot_Rod
09-05-2005, 10:49 PM
I can't remember exactly what the OHMs are for a stock fuel level sending unit, it's something like -243 - +35 ohms. When I did mine Autometer didn't make a gauge compatible with the stock F body intank fuel level sending unit and I don't think they do now either. I had to unplug the stock unit and use a 0-90 OHM Jazz fuel level sending unit and an Autometer 2 1/16" Ultralight fuel level gauge and route new wires for it. Not to bad when your replacing all the stock gauges with aftermarket units.
superchannelkev
09-06-2005, 01:10 AM
have any pic or anything part numbers for the Jazz sender etc? Thanks for your input!
jimmyp
09-06-2005, 08:09 AM
autometer also has their own sending unit, i found. Its only like $25.
Elite_Hot_Rod
09-06-2005, 08:35 AM
From the Jegs on-line catalog.
PN# 547-378-090-03 Tube Type Fuel Level Sending Unit
0-90 Ohm GM
8-1/2'' Long
$79.99
Elite_Hot_Rod
09-06-2005, 08:36 AM
If it's a swing arm type I don't think you will have enough room in the tank for it to work becuase it will hit the stock fuel pump.
jimmyp
09-06-2005, 09:00 AM
i actually have an aluminum cell but youre right, ill bet it wont clear the stock pump assy.
tha dingle
08-25-2006, 02:34 PM
99+ LS1's (plastic tanks) are 33 Ohms Empty and 240 Ohms full. Autometer sells a gauge with these Ohms settings but it is backwards. I have heard autometer has a reverse aircore they will install in the gauge for $12 and make it work with 99+.
