How to do a DS Safety Loop and True Duals?
Any one have pics of there drive shaft safety loop set up? I need to copy it! I have a universal Lakewood DS safety loop and so far I have been unable to get the correct angles to make it fit with the TSP TD's. I am looking for other possibilities. Thanks.
CARTEK Racing
I have that exact setup on my car. I think the problem for most people is not the safety loop and true duals, its the safety loop and torque arm.
The Lakewood peace is made to bolt into the factory tunnel brace location, but if you have your torque arm bolted to that location you would be SOL with the Lakewood loop. I have a Stealth torque arm which mounts to the transmission support, so my ds loop fit without any problems.
Race your car!
You could get a bmr one, and just cut the ends and bend it so that it could be bolted up in the tunnel thru the floor, I have seen one that way before to get it out of the way for the exhaust.
There's alot of ways it can be done, I'd reccommend getting the exhaust on the car, then if you have a local chassis guy, get the car to hi and have one made, that's probably the easiest thing to do and would come out the best.
