fast intake guys with 90mm tb, can i use stock tps sensor for the new 90 tb
fast inake guys with a 90 mm tb, i was wondering if i can use the my stock sensors from my stock tb , for my new wilson manifolds 90 mm tb, cause, i see the that tps is mounted different from the stock one, can i use the same sensors, or do i need to buy new ones and were to i get them?
Location: Your girl's back door giving her the long stroke while you're at work
Your stock sensors should bolt right up. Mine did on my FAST 90 TB but I had to turn the IAC sensor per the FAST instructions
