Swap oil pan, swap windage tray too?
If it fits, then it fits.....
I would be most concerned with bolting on the new oil pump pickup and seeing how it works then.. Since the sump is in the front, then the pickup tube will go almost straight down from the oil pump. The truck sump is in the back, so there may not be clearance in the front of the tray for a pickup tube.
I can tell you that the truck tray and the CTS-V tray are exactly the same. But that's as far as my experience goes...
