>>>True Duals with stock headers?<<<
Old 10-01-2007, 12:11 AM
180ls1's Avatar
Default >>>True Duals with stock headers?<<<
Hey guys i dont want to change my headers cause i live in california but i was thinking about doing true duals with two bullets dumped on my 1999 ls1 m6. Should i just weld a bullet into the i-pipe and dump it? Otherwise i was going to get the slp y pipe for stock headers and then cut it and weld an x pipe on the end of that and then run the bullets dumped. Will i see any more noticible power with the duals vs the i-pipe on a mostly stock ls1 camaro?
Old 10-01-2007, 02:30 AM
stevied916's Avatar
the y pipes arent going to bolt up to your stock manifolds. Just get lt's and change them out when you want to smog
Old 10-01-2007, 03:03 AM
discostu's Avatar
i think he is talking about the stock exhaust dumped before the axle
yes that would be the easyest way of doing it
i cant say if it would sound good
Old 10-01-2007, 04:52 AM
LrngCrv's Avatar
It will be mostly for sound, shouldn't notice much for gains compared to the amount of work and money involved. I wouldn't worry about it unless you wanted to upgrade your exhaust manifolds, or if you just can't stand the sound of your exhaust.
Old 10-01-2007, 07:02 AM
blkZ28spt's Avatar
If you still have an I-pipe you don't have duals.
No, you would not see a noticeable power increase with that setup.
I vote you just get an aftermarket cat-back setup, or maybe a cutout before the muffler. Even both, if you like.
Or just go with some nice longtubes and real true duals.
The best thing you can do is move out of Kalifornia!
Old 10-01-2007, 10:45 AM
night ghost's Avatar
just my two cents,
i would just increase your piping to 2 1/2 or even 3" if possible then just dump them in the middle. believe me you will feel alot faster, regardless of what they say. dumps are a secret to power that alot of people don't know about. i did that at first, but then got my hooker supercomps lt's and now it sounds like a track car lol. with stock headers it might sound a lil nasty though so its up to you.
Old 10-01-2007, 11:41 AM
95 Z28's Avatar
I'm pretty sure the stock manifolds are going to be the bottleneck in your exhaust, so changing around things that are downstream from that aren't going to yeild much of a gain. If you're hellbent on keeping your manifolds then I'd bust out the sawzall and dump it with a bullet and a turn down angled outwards.
Old 10-02-2007, 08:23 PM
blkZ28spt's Avatar
Don't think so
Old 10-02-2007, 08:27 PM
zaner's Avatar
i was always given the impression
dumped exhaust- more hp but less torque since a loss of some backpressure
Old 10-02-2007, 09:31 PM
180ls1's Avatar
i think dumps would give me more power and would be cheaper then running it out the back. Maybe i should just weld a bullet into the y pipe and call it good for now.
Old 10-02-2007, 10:42 PM
King Nothing's Avatar
could always go with shorty headers and you can still have your cats goin into true duals and not mess with emissions . . . thats the way i'm probably gonna go. most people don't realize how bad of a fine you get for removing cats and gettin caught doin it. $1000 or more for lt's sims tuning and welding and $5000 or possibly more for removing your cats and gettin caught or just keepin your emissions?????? i'm votin emissions
Old 10-03-2007, 12:34 AM
180ls1's Avatar
I would be keeping the cats on there and i allready have sims on the car when i bought it so i could do either. i was just thinking for a pure performance stance duals on stock manifolds versus a bullet on the i pipe.
Anyone know where i can get test pipes to bolt in place of my cats?
Old 10-03-2007, 01:11 AM
JTelesone's Avatar
Originally Posted by blkZ28spt
Don't think so
your not going to really "free up" any real power without some headers. I live in the dissasterous state of Ca and just put kooks lts on, lt's are gonna be your best bet for power and sound. If you really dont wanna do it get a good catback with a cutout. Just my .02
Old 10-03-2007, 01:36 AM
chrisdacarnut's Avatar
LT's and high flow cats.
Old 10-03-2007, 09:57 AM
jag42420's Avatar
If you have the money ($779), Bassani makes a 2.5" true duals kit that bolts right up to your stock cats. The stock manifolds flow quite well on a LS1. Headers were much less of a gain that true duals for me. Look up Mrr23 on here or at LS1.com. He dyno tested a 20rwhp gain going TO Bassani true duals FROM an aftermarket catback setup on stock manifolds. My Bassani has been by far my best investment. I noticed a small increase with the headers, but a much nicer increase with the duals. Here's a video I made before the Pacesetters with stock cam and stock cats to give you an idea of the sound: http://s217.photobucket.com/albums/c...nt=Bassani.flv
Old 10-03-2007, 03:12 PM
Vrbas's Avatar
My roommate has a TSP 3" Y-pipe hooked up to his stock headers (CATS and all). He said they had to do some tweaking and "re-shaping" of the pipes, but it's definitely possible. I know b/c his car is right outside and runs fine, looks good too (perfect clearance for his dual electric cutouts too. I dunno how he did it).
I'll try and get some pictures up.
Old 10-03-2007, 10:24 PM
thosewhohatedmecreat's Avatar
get the long tubes and then put in cats in the true dual system, slp sells some high flows....
Old 10-03-2007, 11:13 PM
CAMAROZ28SS's Avatar
get LT's and leave the cats on
Old 10-04-2007, 12:40 AM
180ls1's Avatar
should i just weld my stock cats into the setup? i really dont know if i will have enough money to but two high flow cats.
Old 10-04-2007, 03:54 PM
blkZ28spt's Avatar
Why would you go with longtubes and duals only to install high flow cats?
Once you go with mid length or long tube headers are smog-illegal in Kali. Cats or no cats.
Quick Reply: >>>True Duals with stock headers?<<<
