Finished my exhaust system...and weighed the car...
A little status update on my GT47-88 build...
Here is a pic showing the majority of the system (for reference)...
http://home.comcast.net/~tfranklin5580/upper_cold_1.jpg
Got the exhaust system layed out today....tacked up, to be fully welded up later...pretty simple design. 4" stainless past the motor plate, under the starter into a 4" bullet muffler then a turndown
Also threw the car on the scales....I'm guessing there is about 500 or so more lbs to put in (tranny, converter, gears, driveshaft, race brakes and fuel/water systems mainly)
Came in at a portly 2502 lbs right now
Looks like 3200 lb raceweight is probably an achievable goal...still have about 30-50 lbs that needs to be removed too...(cutting out my old Global west SFCs since the new 25.5 cage has integrated SFCs, install my tubular A-arms in place of the stockers, etc)
Full build details are in the link in my sig...
Originally Posted by SSilverSSurfer
looking good, you doing upper and lower a arms?
Yeah...I have a set of BMRs I picked up used. I need to pull the kmember to do the lowers. I couldn't get one of the bolts to clear when I tried earlier....
