02 Camaro Idling High Issue
Sometimes it does it, sometimes it dont. Push in the clutch or take it out of gear and it will idle up anywhere in between 2K and 3K RPM's. Once you make a complete stop, it drop back down to normal idle. Anyone else seen this?
i adjusted the screw and it the idle went back down to 800 rpm but after driving it to school and stopping and putting it in park it went back up to 13-1400 rpm. I am thinking maybe I need a retune.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by Shoulder Shaker
The same thing is happening to me with my 90mm Fast. I was told maybe the iat can be ajusted or something.
Originally Posted by NHRAMAN
Try cleaning your IAT with some PROPER Cleaner. [MAF Cleaner]
ok i tried cleaning the iat and adding a throttle return spring and it seems fine now when driving but when i stop turn it off and turn it back on. It still idles to 1300 until i put it in drive and it goes back to normal. Oh well 75 bucks for the retune. No christmas presents for me.
It might..mine ran smoother after the 1st time I cleaned them....I use CRC Industries MAF and Connection Cleaner.....available, all over. [autozone]
