oil presure video (w/vid)
so i have wondered this for a while, during a run the oil pressure doesnt stay at the seme pressure it goes up and goes down, but not nesecerily with rpm wonder if you guys could help me out, here is the video sorry for the quality
http://lsx.streetfire.net/video/094a...ba0135211f.htm
Looks kind of low for full throttle. Mine goes to 60 under full throttle and idles at 20. Cruising around 50-60. What oil weight do you use and how many miles on motor? GM general rule of thumb is 10 psi per 1,000 rpms. Are there any ticking noises or knocking? Anything out of the ordinary and when did you first notice it? May also be a lazy sensor. Try a new sensor first.
its has 183xxx on it, kinda high haha. i am using 5w 30 mobil one, it has done this for a long time i just started to think about it the other day. no kicking noises or knocking or anything of the sort, it sounds and runds good
