Throttle Body Before & After Dyno Gains?
Old 10-01-2007, 06:48 PM
5.0stang's Avatar
Default Throttle Body Before & After Dyno Gains?
Does anyone have just a throttle body swap and did it gain power?
What modifications did you have and a post of the dyno graphs would be great
Old 10-01-2007, 07:06 PM
JohnnyC's Avatar
Swapping the throttle body as an early mod is generally considered a no-no. The stock T.B. will flow enough air for most setups, and aftermarket T.B.s can be a bitch to gt running right. I don't know anything about your setup,so I will assume you are a stock or nearly stock LS1. Your best bet as a new comer would be to port and polish your T.B. and spend your money on LT's, exhaust, a lid, cam, suspension, ect. There are countless people on here that wish they had never Fu@#ed with their T.B. Just my experience for what it is worth.
Old 10-01-2007, 07:08 PM
5.0stang's Avatar
Thanks Johnny C.
Just to clarify, I do not own an ls1, etc.
I was just trying to do some research on what actual powerlevel did the aftermarket throttle bodies actually make a difference.
Does anyone got flow numbers for stock throttle bodies or aftermarket throttle bodies?
Stock is 75mm right?
Old 10-01-2007, 07:11 PM
JohnnyC's Avatar
No LS1? I guess I should have seen that from your user name!
If you are speaking in general terms, then I couldn't really give you a H.P. number that makes sense for all TB's for all cars. Cars respond differently to TB swaps - some benefit more than others depending on the stock configuration and the setup.
Old 10-01-2007, 07:16 PM
5.0stang's Avatar
Exactly, that is why I want to see dynos to see how a certain size throttle body compares to the power at hand
Old 10-01-2007, 07:19 PM
JohnnyC's Avatar
You would have to post some specific info on engine type, mods, ect. Otherwise, all anybody can do is guess. It is the internet, after all.
Old 10-01-2007, 09:02 PM
mikenews's Avatar
Factory port and polish TB...gotta love it! FREE FREE did I say FREE Horsepower!
Old 10-02-2007, 04:52 PM
3rdgentug's Avatar
i dont have dyno numbers or anything but i have a p/p thunder racing tb
i didnt notice any real gains from it, im sure it gave me a few though 2 - 4 mabey ???
Quick Reply: Throttle Body Before & After Dyno Gains?
