wickdss
06-05-2003, 06:09 PM
I was just wondering if there was a way to turn the headlight on from the switch only? Not having them go on automatically when you turn the car on.
project9sec
06-05-2003, 06:26 PM
i know there is a wire on the e-brake that when the e-brake is completely released that is when the headlights go on i would play with that im not sure i think it is the same wire as the one that tells you your ebrake is on
Z_Man
06-05-2003, 07:12 PM
http://www.ls1tech.com/threads/showflat.php?Cat=&Board=UBB29&Number=548254&page=0 &view=collapsed&sb=5&o=14&fpart=1
If you disable the DRL module you will lose other things like the BRAKE light...its the light sensor you wanna play with.
