T56 carnage! (PICS)
T56 carnage! (PICS)
Well, ya see, whut happen wuz....
1. 2 or 3 12.4 et passes at Darlington. The best runs I'd ever done, of course! What could go wrong?
2. John Force style burnout on the, as it turned out, final pass of the day.
3. launched hard, it was going to be another good run. Went for 2nd gear and-CRUNCH!...klakady-clunk klackady-clunk. Good thing I had a drive shaft safety loop.
This lil LS1 as a healthy apitite for drivetrain! (5 clutches, 3 rearends, and soon to be on it's 3rd Transmission)
I had this tranny rebuilt by T56 Rebuilds about 20,000 miles ago. Anybody familiar with their warranty?
You are at 385 at the back wheels? And you've gone through 5 clutches, 3 rear ends and going on the 3rd T56? Sounds like you got some major issues... or you are just beating the living crap out of that car every day. Damn.
Agreed ....... the only other time I have seen similiar damage like that was a customer that had a twisted yoke on the driveshaft . The yoke could not compress into the housing properly because of the twisted splines so when the pinion pulled it crowded the the driveshaft and BOOM out goes the lights .
Thanks Amber. I figured It would not be covered but, it never hurts to ask, right?
As far as all the other drivetrain goes, I have put 160,000 on my car since I bought it new back in 1998. It's seen a lot of strip time. The clutches (2 stockers, a Spec 3 & a LS7) just wore out along with the synchros in the original T56. I replaced the 10 bolt with another 10 bolt after the carrier broke. After that one showed signs of going out, I went to a 12 bolt. This is the first time I have shattered anything.
Sounds normal to me for a car that has been driven like a Camaro should be driven for the last 9 years.
I'll check on that. The drive shaft did come from a 10 sec A4 car.
To be honest, I think the LCA relocation brackets (bolt in) I put on did it. After they were put on the whole rear axle was pushed rearward about a half inch. To fix it I ordered some adjustable LCAs from FBodyMotorsports but those bastards didn't get them to me untill over 2 months later! I should not have drove it till I got them on and adjusted.
You have 60 more horsepower than me and 60000 miles more than me. I still cant comprehend going through so many clutches, rears, and transmissions. I'm on my second clutch (stock one went at about 85000), I have the stock 10-bolt with different gears and LSD (stock LSD seemed to be pretty shot, lots of one wheel burnouts), and the original trans, which CAN be notchy when its cold. You must treat that car like ****.
I have a T56 rebuilds tranny as well. You are covered up to a year as long as you are within their horsepower limit. A stage 4 is limited to 700rwhp. That's some serious damage for a car putting out around 385rwhp. I think the damage is due to something other than the tranny. Bad ange on the DS or too much stress from the TQ arm.
Your comment is very offensive. You have never seen my car. My wife would beg to differ about the car getting treated like ****.
