Adding more boost & meth kit, how important is new tuning?
Old 10-02-2007, 07:50 AM
rufretic's Avatar
Default Adding more boost & meth kit, how important is new tuning?
I'm debating changing my pulley for a little more boost and adding a meth kit. I'm already tuned for the 13.5psi I have now with no meth. When adding more boost does the tune need to be changed? I'm adding the meth kit for a little extra insurance. The main reason I'm trying to avoid the tune is that I'm pushing a lot of limits and don't feel very comfortable with the car on the dyno. I would much rather break something at the track going for 9s than on the dyno going for rwhp. I may only get a few passes out of it and I would be really pissed if it broke before I even made it to the track. Any good words of advise on what I should do would be appreciated.
Old 10-02-2007, 08:54 AM
LS1Tech Sponsor
hellbents10's Avatar
Do you have a wideband and some way of monitoring kr? Is your fuel system good for it, or are you using the meth for extra fuel too?
Old 10-02-2007, 09:09 AM
rufretic's Avatar
No wide band just an air fuel gauge. My fuel system should be good to 900rwhp, dual inline pumps that are boost regulated and 60lb injectors. Also will be running race gas.
Old 10-02-2007, 10:07 AM
Speed's Avatar
You really should tune to operating conditions. It's hard to guesstimate how your car will respond with more boost and meth without some way to gauge it. Personally, I would tune to your highest operating output and turn down from there. You will probably be fine but it's a lot to risk in case something does go to hell.
Old 10-02-2007, 10:09 AM
cablebandit's Avatar
you need a wideband....detonation does its damage quickly...and it doesnt always give you a warning.....just POOF....deposit 5000 dollars please
Old 10-02-2007, 10:46 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
For sure get a wideband. And with meth, you want to keep the AFR around 10.9~11.0. From this, you can get it roughly dialed in without a complete tune...
Quick Reply: Adding more boost & meth kit, how important is new tuning?
