Factory filled units
If your auto tranny does not have a filler tube (e.g., Ford, BMW) is there a filler plug on the side of the case where you can add/change fliud?
I would assume this is the case since the factory filled units have a stamped tranny pan with standard bolts that is used to access the valve body, drum bands, filter, etc.
Thanks...
Thanks...
