Stock studs and prostars w/grinded calipers? Did search, no straight answer.
I put on my front prostars, I grind the calipers to make them fit, no spacer.
The stock stud hardly comes all the way through, is this ok with shank style lugs?
When I did all the grinding to get get the Pro Stars on I was under the assumption that the stock studs would be ok on the front as long as I did not use a spacer. I do have 1/2" x 3" studs in the back.
I plan to put the 3" studs in the front, but thought I could get away with it for now. Will I be ok?
TYIA!
TYIA!
I understand they wont pass tech. I just meant until I get the front studs in, is it ok to run with these. The track I go to has 0 tech, lol you driving it in and paying $10 = tech. I just did not realize until last minute how short they seem and want to know if it will be ok with a trip or 2 to the track.
OWN3D BY MY PROF!
I've seen quite a few people shear off stock wheel studs with prostars.
You could also do this:
https://ls1tech.com/forums/multimedia-exchange/503176-picture-year.html
FYI i had a front caliper break on me only a week after grinding them. i was lucky and i t broke in the burnout box with the line lock set....
car has been sittin for a month now waiting for the money to get new calipers studs and spacers. i blew all the money on the rims LOL
I use the prostars with no spacers and stock front studs. I used the ARP in the rear but not the front. The rule in engagement is that amount of thread to stud engagement has to be equal or greater than the diameter of the stud in order to attain full strength. anymore engagement is not necessary to achieve full tensiel strength of the stud. I measured and had over .600 of engagement using the stock studs. The 12mm studs are less than .500 diameter.
