Problem with AFR 210 Head HELP
I cant get my head stud to fit in one of the holes on both heads has anyone else had this problem I am using ARP 234-4301 head stud which is what afr says i need to use. It looks like there is some metal piece in the hole keeping it from going through any suggestions or ideas
My spring shims were to big and i too had problems getting my bolts through. So i just mad adjustment to the washer i was using. But i didnt have problems with that hole i had problems with the middle bolt hole.
