how to instal water pump drive shaft
Old 10-02-2007, 09:17 PM
transam1577's Avatar
Default how to instal water pump drive shaft
just wondering if any of you guys have got any tricks to installing the water pump drive shaft seal because the tool is almost 100 bucks
Old 10-02-2007, 09:24 PM
buffman's Avatar
sharpie pen cap with the pocket clip removed and sanded smooth. appropriate size socket. I've thought about having the tool made up..
Old 10-04-2007, 06:09 PM
TXFORMULA's Avatar
do you mean the freeze plug? the sort of brass looking thing that pops into the back ? i JUST did this so pm me if you need to
Old 10-04-2007, 07:11 PM
iceman15's Avatar
I used a number of sockets to stretch out the seal, started with a small socket then worked my way bigger until you are able to slip in on the driveshaft coupler which should line up flush with the spline then you can just slide it over
Old 10-04-2007, 08:25 PM
TXFORMULA's Avatar
oohh...you guys are talking about a stock water pump. sorry transam1517,if i confused you,i was talking about an electric one...
Quick Reply: how to instal water pump drive shaft
