How to repair fiberglass?
I replaced my window motor, and noticed that the rivets had worn a little loose and started to rip down on the fiberglass, I replaced the motor, but used bolts instead, and tightened them well, it has ripped enough now that the window is way off in front, and not touching weather stripping all the way? Is there like a bondo for plexiglass? Or what can I use to rebuild/strengthen the inside of my door? If pictures will help, I will get them asap.....
Walmart sells a fiberglass repair kit. It comes with everything you need to repair it with. Just read and follow the instructions. Any auto parts store should sell it as well.
