S-sguy
10-03-2007, 10:56 AM
My car has the slp air filter set up, but has the stock MAS on it. I cant get the MAS to pull off, there is no screws or anything its just stuck. Does anyone have any advice
ssgunny
10-03-2007, 01:05 PM
If I remember correctly the stock MAF slides in to the stock and aftermarket lids and are secured with a hose clamp. If you have the clips on the front that hold down the lid released and the hose clamp removed then as long as you are able to clear the lid's tabs in the back from the base the MAF and lid should seperate.
