Truck Manifold guy's Inside????
Old 10-03-2007, 09:34 PM
HUNTER02SS's Avatar
Default Truck Manifold guy's Inside????
What gasket's are you all using from the manifold flange to the up pipe flange? The one with 3 bolt hole's in it. I used this new style high temp gasket with a metal insert in the middle and it just spit's them out! Burn's the metal insert into pieces! What gasket work's best for you guy's!
Old 10-03-2007, 10:22 PM
slowbrakiller's Avatar
i dunno about gaskets, but a v-band would work nicely
Old 10-03-2007, 10:24 PM
frcefed98's Avatar
RTV...high temp copper RTV.
I used the carbon gaskets, but it spit those out too...so I went back to what was working in the first place.
J
Old 10-03-2007, 10:49 PM
bigtymn's Avatar
stock truck metal o rings
Old 10-04-2007, 06:52 AM
smokinHawk's Avatar
high temp rtv, no leaks no problems.
Old 10-04-2007, 07:05 AM
Mr.MartyStone's Avatar
Like everyone else said, high temp RTV. Only thing that lasts.
Marty
Old 10-04-2007, 08:03 AM
HUNTER02SS's Avatar
Just use the high temp rtv without a gasket. The rtv will make the gasket! cool I will do this!
Old 10-04-2007, 08:52 AM
cablebandit's Avatar
i used high temp rtb to join the incon ypipe to the downpipes and it never leaked
Old 10-04-2007, 11:02 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
RTV but the passenger side has needed to be reapplied twice.
Old 10-04-2007, 11:43 AM
smokinHawk's Avatar
were you able to check to see if your flange was warped john?
Old 10-04-2007, 01:24 PM
LS1Tech Co-Founder
Did not appear to be. I might try to use the factory o-rings over winter.
Old 10-08-2007, 11:08 PM
bigtymn's Avatar
thats what i have does not leak and there cheap!!!
Old 10-09-2007, 02:03 AM
blown90lx's Avatar
Copper RTV
Old 10-09-2007, 11:57 AM
bigturboz28's Avatar
I made a set of gaskets using 1mm thick disk of copper with 4mm dia. holes in it, then put a thick bead of High Temp Silicone Gasket Goop on both sides (holes are used to anchor the silicone). Looks like it will work real good, haven't tried 'em yet.
