General LSX Automobile Discussion - Why is the PCV valve grounded?
View Full Version : Why is the PCV valve grounded?
8a8mfh
10-05-2007, 01:27 AM
with a pretty big wire too, any ideas?
jmm98LS1
10-05-2007, 09:16 AM
The pcv valve is controlled by vacuum, not electricity.....not sure why there'd be any wiring there.:confused:
BIG_MIKE2005
10-05-2007, 10:21 AM
I have wondered this also cause it attaches to the passanger side water cross over tube on a stock application. Or the block off plug on a LS6 coolant conversion.
y2k_ta
10-05-2007, 10:29 AM
I assumed it was just a mounting strap for the pcv valve.
8a8mfh
10-05-2007, 02:40 PM
Could be but it's round electrical wire.
H8Mac
10-05-2007, 02:41 PM
I Have Wondered The Same Thing!
9silverbird8
10-05-2007, 03:34 PM
I believe the strap has nothing to do with electricity, but more to do with keeping the valve from freezing open or closed in colder conditions.
8a8mfh
10-05-2007, 04:11 PM
Heat transfer helps warm it?
Took me a second to figure that out.
Have you ever seen one frozen due to cold weather?
Sharpe
10-05-2007, 04:21 PM
Because it got caught looking at nudie mags.
I TOLD YOU THOSE WERE TONY'S, MA!!!!
9silverbird8
10-06-2007, 12:23 AM
I haven't, no.
RPM WS6
10-06-2007, 01:03 AM
It's not grounded.
That wire is a heat sink.
The end. :)
8a8mfh
10-06-2007, 01:09 AM
It's not grounded.
The end. :)
Ok, why do you need a heat sink on it?
Only thing I can guess is so it heats the pcv valve. I remember pulling the pcv valve out of several healthy gen 1's to find milky condensation on it.
Is this the idea? Heats it up to evaporate the moisture?
