are lt4 intakes Red?
The ports and plenum of the LT4 intake are the same as the late LT1 intake, the difference is in the amount of material above the port. The LT4 heads had taller ports and that extra material is needed to seal well too them and also leaves opportunity for port matching. If you try and put an LT4 intake on LT1 heads though that extra material interferes with the valve cover rail. Two options then have the heads machined so the rail is thinner, or machine that extra material off the LT4 intake effectively making it an expensive red LT1 intake ruining all potential it may have had. Basically you are looking to waste time and money, you want a red intake get an LT1 one coated or painted. I painted mine with parts store sourced engine enamal and it looks decent, went with black, then cleared the raised ribs on top. A friend did the work when mid project we hit a parts snag and he got bored.
ok cool thanks for the info i just got the intake on a trade...so basicly i should just stick with my lt1 intake....anyone need a lt4 intake.. it does have some minor porting done to it.
