1LE mount?
Old 10-05-2007, 06:45 PM
djsanchez2's Avatar
Default 1LE mount?
Where could i buy this piece. I'm gonna go with urathane motor mounts and 1LE trans mount but can't seem to find the trans mount anywhere.
Anyone know who still sells em'?
Old 10-05-2007, 07:37 PM
Redlinez's Avatar
I was told the new mount is the 1LE. Like they stopped making the regular OE mounts. I hope that is true as I love my last 1LE mount 3 years ago.
Old 10-05-2007, 08:07 PM
djsanchez2's Avatar
Cool thanks. I'll have to check on that.
Old 10-06-2007, 08:13 PM
djsanchez2's Avatar
Who is "they"? sorry forgot to ask. I can't find a trans mount on gmpartsdirect or SDparts. Everywhere else i looked all have are poly mounts.
Old 10-06-2007, 09:06 PM
studderin's Avatar
were did you hear that? I need to get one.
Old 10-06-2007, 09:33 PM
Mr. Trick's Avatar
What makes the 1LE mount so good? I'm just wondering because $72 seems kinda steep to me, that what I was quoted at the dealership.
Old 10-06-2007, 10:05 PM
djsanchez2's Avatar
Well that's dealership prices. Ouch btw!! But it is a firmer rubber formula than the stocker. It can take some abuse, and it is not as harsh as the Poly mounts. My car is a DD so i would like to keep the components that add to the interior vibes at a minimum.
Old 10-07-2007, 08:44 AM
Arad's Avatar
I wanted a rubber one too, but was qouted over $80 for a new one at the stealership. I went with a poly one that was under $30.
Old 10-07-2007, 02:31 PM
hpjunky98's Avatar
I spent a long time getting the 1LE mount and paid like 85 bucks for it from my local chevy dealer, and it looked a bit different, but felt the same in the car. didn't fix the shifter movment at all. just pick up a poly trans mount from autozone.
Old 10-07-2007, 05:13 PM
djsanchez2's Avatar
I might end up just biting the bullet and going poly as i'm going tunnel mount T.arm soon.
Old 10-08-2007, 03:22 PM
BackinBlack02SS's Avatar
Starting in 2001, the 1LE transmission mount became the only mount produced.
Old 10-09-2007, 08:14 PM
thunderdan74's Avatar
I have a Camaro book that says 96 and up camaros all have the 1LE parts integrated.
Old 10-10-2007, 05:27 PM
djsanchez2's Avatar
Cool.
Old 10-10-2007, 07:31 PM
The book you have lists false information. Up until 2000 the 1LE option was an actual RPO code that included bigger sway bars, transmission mount, different shocks, lower control arms and panhard bar with solid rubber bushings, as well as front control arms with solid rubber bushings. Beginning in 2001 GM no longer offered the 1LE option as an RPO code. It became an option only available through SLP on SS and firehawks. The transmission mount was no longer included in the package because it now was included on ALL f bodies.
Old 10-11-2007, 04:24 PM
bad6as's Avatar
i have a es trans mount in mine. i grinded off the 2 nubs and i did not use the plate. i have no issues
Quick Reply: 1LE mount?
