opti swap
opti swap
im changin my opti i have everything off except the crank pulley and im just wondering how exactly do u line the new opti up i no u have to alighn the crank trigger or sumthing im just worried i got in a lil over my head so any advice would help thanks
http://shbox.com/1/93-94_opti.jpg
your 94 wont have a crank sensor. just align the opti drive pin like it shows on the weblink and that is it. it is a little tricky to line up sometimes, may take you a try or two. do not force it. also if you are taking the crankshaft hub off, note how it comes off. there is an arrow that must be lined back up to properly orientate it. i usually install the opti and balancer back on and start it up for a sec. just to make sure everything is good before putting it back together. good luck
