Whats are signs of clutch giving up?
Old 10-06-2007, 04:13 AM
DarkLoneWolf666's Avatar
Default Whats are signs of clutch giving up?
Okay i dont know if it's me. . but what are signs that the clutch is giving up. Because i either feel like im lazy to push down the clutch to put it into gear but it grinds ( never happen before) or my clutch is giving up on me after putting over 100+hp on to my LS1 Camaro Z28 2000.
Old 10-06-2007, 10:48 AM
lsp408's Avatar
if it slip, clutch is done. try drive on 5th and wot see if clutch hold up.
if it grinds, maybe the syncro is going bad
Old 10-06-2007, 12:04 PM
brad8266's Avatar
If it slips it is bad. A heads up beforehand would be the release point coming up farther and farther till eventually it slips.
Old 10-08-2007, 12:14 AM
kenp's Avatar
Bad master or throwout might cause the problem you describe.
Old 10-10-2007, 07:34 PM
i just found out. . it always happen when im tired. .lazy. . lolz. Morning kinda explains it because it always happen in the morning. LOLZ.
Old 10-11-2007, 01:16 PM
PewterScreaminMach's Avatar
Well, if you do want to check on the clutch giving up, the first response was good advice. Throw it in 5th or 6th at a highway cruising speed and floor it. If it winds out and slips before grabbing, it's time for a new clutch.
Old 10-11-2007, 08:54 PM
thanks for the tip. ill try it when i can.
Quick Reply: Whats are signs of clutch giving up?
