Turbo guys how many 02 sensors do you use?
Old 10-06-2007, 08:17 AM
KWIKKAR's Avatar
Default Turbo guys how many 02 sensors do you use?
Just looked on my APS kit while installing it and it has 4 spots for 02 sensors. On my old H/C I only used the front two 02's can I just use the fronts or do I need to buy two more and use all four. Thanks
Old 10-06-2007, 08:27 AM
smokinHawk's Avatar
i am just using two, both on each bank in the up-pipe.
you will be fine with just the two as long as you have it programmed out of the computer
Old 10-06-2007, 05:42 PM
KWIKKAR's Avatar
But does it make a HP difference to run 4 instead of 2. I'll need two plugs for the rear 02s if I dont use them.
Old 10-06-2007, 05:53 PM
calongo_SS's Avatar
the rear o2's are only for verifying cat function. it's kind of pointless that the bungs are even on the aps down pipes. It's a good place for a wideband(s) though.
Old 10-06-2007, 06:09 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
not unless the back 2 are in the downpipes.i havent seen the pics so i dont know where the holes are located.
Old 10-07-2007, 01:04 AM
calongo_SS's Avatar
They are in the downpipes on the APS kit.
Old 10-07-2007, 05:14 AM
JMBLOWNWS6's Avatar
My fast dual wideband will be right at home LOL
Quick Reply: Turbo guys how many 02 sensors do you use?
