What do you think i will run?
Last October, with my 2002 Trans Am i ran a 13.3 @ 108 with a 2.2 60 ft At the time all i had was Full Exhaust.. LTs and True Duals (H Pipe) lid and K&N air filter. That was it. And my stock LS6 clutch was slipping too.
So it is that time to go to the track again. The 21st of Cotober. Same car, all that changed was cam.. 228/232 .588/.595 110+4, P&P TB, ASP UDP, WS6 hood WITH the WS6 lower air box... Same slipping LS6 clutch and same tires as last year
so what do you guys think that will run? Oh and i have all the FREE MODS too.
HP numbers are in sig
Retired Street Racer
12.8 @ 113
*And for the record, (no offense to you) I am tired of these "What will I run" threads. Just take your ******* car to the track and see what it runs. Because if it doesn't run what someone on the net says it should, then you create one of those, "Why is my car so slow" threads. ******* stupid!
Ok, I'm done ranting and going back to bed.
12.8 @ 113
that is all
A local guy here with H/C car ran a 12.5 @ 115 last week at Memphis with stock 16X8's and street tires. I was impressed with how he was launching the car.....no spin at all. Granted he was in the 2.1 to 2.2 60' range, but very impressive for street tires nonetheless. I'd say you'll run some really good trap speeds and high 12's. Good luck!
thanks you sir i will need the luck......
BTW, what psi do you run street tires on? i was thinking 22 PSI???
just run your street tires the way that you would run them on the street man. Unfortunately, im with Matt D on this one, 12.8 @ 113 sounds just about right. I know this bc i went the same route with my car when it was cam only, lol Once you get your setup dialed in further, the et's will just drop and drop and drop..
It happens with every 400rwhp 6 speed car with a stock 10 bolt. The mph is there but the E.T. isn't due to the lack of launching the car. There should be a sticky saying, "Want to know what your car will run? Step Inside." And then we can list all of these things. Oh, who am I kidding, no one reads those.
Nice Matt.. i trust ya with the statistics... LOL
i will post what i run in 2 weeks. I hope it will be 12's
I hope to runs 12's with my slipping clutch and stock rear with street tires. And **** if i let you drive, yes my car will run 12's, but likre James's car i will be replacing the rear at the beginning of next year
hmmmm i should stage it like jay, back tires at the front of the line. that was funny
