looking to upgrade some cam, etc whatdya think of this before i order
Old 10-06-2007, 11:23 AM
bricez28's Avatar
Default looking to upgrade some cam, etc whatdya think of this before i order
http://store.summitracing.com/checkout/cart.asp
Old 10-06-2007, 11:53 AM
B4CZR2's Avatar
I think your Shopping cart is empty
Old 10-06-2007, 12:19 PM
1997compT/A's Avatar
See the ".asp"? Active Server Page. All of that is based off cookies on your computer. Nobody else can see that.
Old 10-07-2007, 12:31 AM
bricez28's Avatar
**** lol. cca 007-503-8 cam, magnum 1.6 rr's and 10308-1 crane sring kit.
bricez28's Avatar
why did i think that would work? lol
Old 10-07-2007, 10:04 AM
96capricemgr's Avatar
Do you have a stall if A4 and gears wether M6 or A4? If you answer anything other than yes then you need those parts first.
I say this as someone who made the mistake of camming before gears and stall.
Old 10-07-2007, 10:52 AM
bricez28's Avatar
i have a m6, but it had 3:42s. why do u have to do gears first? i never understood that.
Old 10-07-2007, 01:06 PM
LT1Falcon's Avatar
higher gears keep you in the high rpms more which is what you want and need with a big (high rpm) cam.
Old 10-07-2007, 01:56 PM
With 3.42s you have an all but useless 6th gear in the car, go numerically higher in the rear and get a much harder launch and still maintain highway manners by being able to actually use 6th gear. 4.10s are a good match to the .50 OD.
Like I said I made this mistake, the car did not run any faster till I gave it the supporting parts it should have had first.
If you don't believe me go ahead and repeat the same mistake so many of us have already made. Might as well stop coming to the forum too because if you wont let us help you learn from our mistakes the forum is useless to you anyway.
Old 10-07-2007, 02:53 PM
bricez28's Avatar
no i live by what you guys tell me i just was always curious why it wouldnt work with gears, but now i get it. ill definatly get the 4:10's done first, then the whole cam setup. i hate to think about it but i know im gunna hafta drop 2k on a damn rear soon anyway. thanks for the help.
Quick Reply: looking to upgrade some cam, etc whatdya think of this before i order
