Help, car stumbles and I can smell raw fuel!
Old 10-06-2007, 07:50 PM
69gto96z's Avatar
Default Help, car stumbles and I can smell raw fuel!
Car threw a P0100, and runs real rich! It just randomly started doing this while driving. The car kinda jerks when driving, and is having a HARD time accelerating. When I put it in neutral to slow down, the car idles itself up to around 1800 and stays there, then at a complete stop, it idles down to like 400 and tries to die, and I can smell raw fuel. I put anoter MAF in it that I know is good, and cleared the code. Started it, and the light popped back on and did the same thing. Im stumped. I am afraid to drive it with it doing this. I replaced the pigtail about a year ago, and havent had any problems until the other day. Any help would be greatly appreciated!
Old 10-06-2007, 11:31 PM
96lt1m6's Avatar
http://z28.com/forum/showthread.php?t=36071
DTC P0101 Mass Air Flow (MAF) Sensor Performance
i would double check your connection,possibly disconnect the MAF the pcm will go to MAP instead should run better if this is the problem.
Old 10-06-2007, 11:37 PM
z28hustle's Avatar
so we can run the lt1s (after 93) without the MAF's? and it will be OK?
Old 10-07-2007, 12:23 AM
96lt1m6's Avatar
not saying it will run perfectly,it will run better than having a MAF problem our cars have both MAF and MAP,you will have a SES light unless it is tuned out of the PCM.
check the pink wire going to the MAF it may be broken or something.
Old 10-07-2007, 12:39 AM
ThoR294's Avatar
aye. check the wiring
Quick Reply: Help, car stumbles and I can smell raw fuel!
