Drag Racing Tech
325/50/15 MT DR guys, break in and burnout/psi ?'s
Old 10-06-2007, 10:25 PM
OutlawZ's Avatar
Default 325/50/15 MT DR guys, break in and burnout/psi ?'s
Hey guys I'm getting ready to mount my 325/50 DR's on a brand new set of Bogart D10's and i'm wondering what the break in procedures and burnout techniques that the big boys are using. I've heard about super long burnouts and 17psi but wanted to find out what everyone is doing to get these tires to hook hard. I want some 1.3x 60 foots once I'm done.....
Old 10-06-2007, 11:47 PM
gator's 99TA's Avatar
i am not a "big boy" but i have gone 1.3 60' on that tire. IMO run higher psi. start with 18 psi and see if you can hook. i found my best runs at 20 psi and short burnouts. big burnouts made them greasy.
Old 10-07-2007, 03:04 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I started with 18 psi and went down to 17 on the next pass. Short burnouts and keep the rear shocks on the stiffer side. If your car unloads the suspension the nose will come down and then the car will wheel hop.
Old 10-07-2007, 03:09 PM
minytrker's Avatar
I run 18-20psi on mine but I have to do big burnouts or they wont hook. Thats leaving on gas, if I leave on motor I can do a short burnout.
Old 10-07-2007, 11:23 PM
OutlawZ's Avatar
cool guys thanks for the input..... so i guess 17-20 psi is where i'll start.....
PSJ what are your rears set at? I'm assuming QA1's..... i was thinking start in the low numbers soft (like between 1 and 4) and stiffen them up if they won't hook...
Old 10-08-2007, 08:10 AM
LS1Tech Co-Founder
I had my rears at 8 hard, and then went to 7.
Old 10-10-2007, 11:31 PM
chrismorales75's Avatar
My buddy's blown chevelle runs tire pressure at 15 psi, it is a 275 60 15 m/t et street radial. Just burn out till the tire just starts to show smoke and roll out.
I'd start at 20 psi.
Car has gone 8.30's in the 1/4 on that tire with that burnout method.
Old 10-10-2007, 11:37 PM
Twin76mmTA's Avatar
sounds like a wild street car
Old 10-11-2007, 12:26 AM
it's a sbc with a big vortech blower and blow through carb, makes about 1400-1500 hp, run's 8.30 usually around 160 mph, with 60fts around mid to high 1.3's
Love those drag radial cars, what was great was seeing another buddy spin the tires get out of it and back in it and still run 190 mph on a 315 60 15, with 3.08 gears
Quick Reply: 325/50/15 MT DR guys, break in and burnout/psi ?'s
