SUTTERERMAN85
10-07-2007, 03:28 PM
ok guys i am wanting to go with a new cam that will peak around 6800. i want to shift at 7000 and i want it to have less overlap than my cam now has 22* @ .050"
my cam now- i was wanting the nasty lope and beastly midrange power which is does very well. the bucking sucks in traffic which i do a lot of but i knew what my cam was going to be like when i had it ground and i can live with it if i have to. my cam now just seems to run out of steam up above 6k. havent had it dynoed or anything and have a 12.6-12.8 afr all the way through on the WB. im running 30* of timming and have a SCR of 11.1-11.2. milled .025" and a .040 gasket.
i am thinking of a cam on a 114ish lsa in the 240-246 range but i dont know anything about valve events so i am open to some schooling and opinions.
summary- i want a more driveable car (less bucking) and more topend power. my solution for this is a larger Dur cam on a tighter LSA so it has less overlap. no sure if this is the thing to do or not. from reading other posts a 12* split cam is a bit much for a N/A motor. i see most people running 6-8* with l92 heads.
also thinking about going with a carb intake and elbow.
Thanks in advance guys.
Nick
Nick
