MAF QUESTIONS. 90mm???
I have a fast 90 mm intake and tb. I have an 85 mm delphi truck maf. I have to be losing airflow. Does anyone make a 90 or 95mm MAF? I also need to know where to get a pigtail so I can hook my stock 3 pin into the 5 pin. I really need help on this.
I don't think there is a 90 MM maf out there at this time.If you wanted to go bigger you could purchase a cartridge style maf from GM off a 2006 or newer Z06 and put it in a 4 inch tube.Then you would have to adjust for this in your maf table in your PCM. Katech makes a 3 to 5 pin connector or conversion for what your looking for along with Speed Inc. and Speartech.Traver
Lingenfelter makes a 100mm MAF, I looked at it but passed when it seemed best for FI. Since I couldn't find any sponsors carrying it I guess it's ok to say, Pace Performance has the pigtail for $23, part #CAS108100.
