oil pressure sending unit question
im gettin rather low pressure. and i noticed that my oil pressure sending unit only feels like there is one (1) wire goin to it... is there supposed to be 2 on the clip thingy or what?
thanks
thanks
Restricted User
I believe it's a two pin connector. If you're seeing your gauge working at all it should be reading correctly unless there's a poor connection. Get out and listen for increased valve train noise. If your motor's making a racket you may need to do some detective work.
we hooked a mech. gauge to it and the gauge in the car is slightly off by a few psi so its not an electrial problem, i have the ported ls6 oil pump in the car but when the motor blew it locked up? so maybe it damaged the oil pump? wat do u guys think
