Max mm throttle body mod
How big can you port a stock throttle body to?
If you are not running coolant through the stock throttle body can't you just port it out and install a bigger throttle blade?
Has any one done this and what is the biggest size you can run on a stock LS1 intake?
I know that machining it out and making a new throttle plate would be cheaper than an after market throttle body, so who has done it?
