Who's Running Kicker Solo's
Old 10-08-2007, 08:31 PM
JeaneGrae's Avatar
Default Who's Running Kicker Solo's
Please post any comments on the size solobaric you are running, what amp, and what type of enclosure you have it in. Would you recommend this sub to someone who listens to rap, R&B and jazz? Pics also if you have them.
Old 10-08-2007, 08:52 PM
Gordon0652's Avatar
I think subthump has some pics of thoes subs in a hatch box, cant be sure theo. Take a look.
Old 10-09-2007, 11:13 PM
bbal4now's Avatar
hmmmm..... I am not sure if you are talking about just Solobaric's in general or the Solo X subs. Anyways, here are some pics of my setup I am working on w/ 3 10" 2ohm L7's They are run off of two kx 600.1's (strapped together). The box is an entire mold of the t-top well (unsure of actual airspace because I got so excited once I finished that I just had to put the subs in to see what it sounded like). Anyways it has a ways to go but you will get the idea at least for the subs. Hope that gives you some ideas and good luck with your setup.
Attached Thumbnails Who's Running Kicker Solo's-1.jpg   Who's Running Kicker Solo's-2.jpg   Who's Running Kicker Solo's-3.jpg   Who's Running Kicker Solo's-4.jpg
Old 10-10-2007, 11:51 AM
KEE AUDIO's Avatar
I am currently finishing a 10" L7 stealth enclosure for a client that wanted one. It is a fiberglass with mdf face unit that saves a bit of weight.
Old 10-10-2007, 12:32 PM
Firestarter!'s Avatar
I would call Kicker's tech support and have them give you the correct volume area for what you want to do.
Old 10-10-2007, 01:59 PM
camaro-94-z28's Avatar
when a sub is upside down like that does it sound diffrent. im not sure what the point is besides looks??
Old 10-10-2007, 03:36 PM
thosewhohatedmecreat's Avatar
reverse mounting a sub makes it sound basicly the same, you get a bit of coil noise, thats it, dont forget to reverse the polaritys on a reverse mounted sub
Old 10-10-2007, 03:49 PM
KEE AUDIO's Avatar
A 10" L7 solobaric requires .66 ft^3 of airspace volume which is almost exactly the same amount of airspace (.6-.7) a stealth enclosure has. I checked it before I built it to make sure what he was asking for was going to work.
I can see an L7 working for that type of music...especially the rap stuff ( I still listen to old school rap from time to time). L7's move a fair amount of air. I think you'd like it for what you are asking.
Old 10-10-2007, 05:38 PM
QWIK Z of OP's Avatar
lets see a picture of the L7 box after you are done with it. ^^^
Old 10-10-2007, 07:42 PM
wickedwarlock's Avatar
Solox requires allot of space and two times the power.
running a pair of 12s will move more air if that's what you want.
You can run two 15" L7s using subthump's deep box. You have to request the box, he doesn't offer it on the site with 15s. It meets the minimal requirements per sub.
Old 10-10-2007, 08:31 PM
KEE AUDIO's Avatar
Will do.
Old 10-11-2007, 12:20 AM
ultraz's Avatar
I have 2 -10" L7's.......... only had one hooked up for the past year and it was plenty loud........ Just hooked the other one up along with it and its pretty astonishing. have them in 2 fiberglass boxes I made, one for each side of the hatch, sealed.
PS: Im giving them 1450W rms and they are loving it........... The guy with 3 10" L7's could use a little more amp to push the woofers to maximum efficiency.
Old 10-11-2007, 12:40 AM
LawHorn's Avatar
I have the old L5 10" in a subthump box. Havent hooked it up yet. Going with a 400.1 Kicker XZ amp
Old 10-11-2007, 03:56 PM
KEE AUDIO's Avatar
Here it is...I'm just done and about to ship it out!! I actually kinda liked it without the carpet too. (Sorry for the cell phone pics my Cybershot was out of battery).
Old 10-11-2007, 09:01 PM
WOW! you have some awesome talent! i have no idea how to work with fiberglass! that looks awesome! is that for a 10"?
Old 10-12-2007, 03:20 AM
KEE AUDIO's Avatar
Yes it is for the 10" and thanks!!
Old 10-15-2007, 10:28 AM
RooRnZ28's Avatar
crappy pic, but they are 2 L5 10" subs with a zapco amp underneath. not much to look at, but they have lasted 5 years
Old 10-15-2007, 12:27 PM
blackbird007's Avatar
12" L7 with MTX 801D amp and 1 farad cap. I tried to make it into one unit so it would be easy to take out for t-top storage. If I remember correctly I think the box is 1 cubic foot. Sounds awesome but im thinking of selling it and getting a 10" L7 and stealth box.
Quick Reply: Who's Running Kicker Solo's
