Replacement oil press sending unit?
Old 10-08-2007, 08:50 PM
fasttimes1's Avatar
Default Replacement oil press sending unit?
Alright, Ive done a search and still cant find an answer. I had a problem with my oil pressure on my pillar gauge flickering so I took a look into it. The gauge on the dash looks solid and motor runs and sounds fine, so I took a look at the wiring for the pillar gauge and found the problem. I have a oil pressure sending unit mounted right above the oil filter; the wire going to the terminal on the top of it was just wrapped around it and a peice of electrical tape over the top(not my work by the way). I found that the terminal stud was loose and the nut was stripped on the stud.
Is there only one type of sending unit to replace this one, or is it pretty much just a universal unit? I cant find a part number on it. It looks like an old school chevy one, a big, bell-shaped assembly.
