Automatic Transmission - OD in my 4l80e doesn't work correctly...
crpjaviman1
10-08-2007, 11:47 PM
My '92 K2500 4x4 has a 4l80e trans. My OD is not functioning right or left (ha). OD engages upto about 65 mph but then it downshifts to 3rd.
I have changed alot things, close to rebuilding the dang thing. I changed the solenoids because when it shifted, it slammed in each gear.
Here is a small list of the things that I have changed:
converter
solenoid (three sets, last one from GM)
pressure reg
od solenoid
cleaned the valve body
ECM
TPS :bang:
I recently scanned the trans and I saw that the speed that the trans was showing was about 20 more than the speedo was registering.
Is this correct? I asked a couple of mechanic friends but they did not know alot about electronic trans.
After reading alot different forums and websites, I have found out that the computer may think that it is towing something and that maybe the reason for the downshift.
Is there a method of calibrating the little box that reads the speed sensor (VSS)? :confused:
If there are any other suggestions, I would like to hear them.
Thanks for any help in advance.
performabuilt
10-09-2007, 12:46 AM
If the PCM does not see lockup it may disable fourth have you had a scanner on it to actually see whats its doing ?
beardWS6
10-09-2007, 02:00 AM
PM`d you performabuilt.
crpjaviman1
10-09-2007, 10:01 PM
I did scan it a few days ago but the only thing I remember is the mph difference. i will need to go back to my friend and get the specs from the file I saved on the scanner.
Is there any specs I need to watch for?
