IAC and Advance Question
At idle at IAC is at 49-51 mostly right on 50 but the Advance is ( from what efi is showing ) is bouncing around. But when I use the EFILives Control Panel and forced the IAC to 50 and try to see what RPM is was sitting at.
So what is EFI doing that when the IAC is forced, the timing sat at 21.5, but when running at 50 normally its bouncing all over?
From what I see, setting my Idle RPMs at 830 or 835 looks to be the best.
MAF Raw, IAC, ADV, MAF, RPM, gms/cyl using ( 15* MAF/RPM rounded up to 2 decimal places)
Sample while AIC is forced at 50 with EFI
2739 50 21.5 8.88 814 0.16
2744 50 21.5 8.91 838 0.16
2751 50 21.5 8.96 834 0.16
2746 50 21.5 8.92 854 0.16
2744 50 21.5 8.91 836 0.16
2741 50 21.5 8.89 828 0.16
Sample just running with IAC at a constant 50
2746 50 22 8.92 812 0.16
2728 50 21.5 8.79 822 0.16
2734 50 14.5 8.84 815 0.16
2720 50 21.5 8.73 830 0.16
2727 50 21.5 8.78 836 0.16
2734 50 21.5 8.84 847 0.16
2746 50 21 8.92 859 0.16
