issue with reverse
issue with reverse
It's hard as hell to put the reverse in my T-56 I already check master n' slave cylinders, fluid level and the clutch itself, evrything looks ok but i need to pull/push really hard to get on reverse. Anybody knows here what should be the problem??????????/
Thats just oposite and wrong advice.The reverese solenoid requires powering to open the gate. It should get reverse easily with the key on/ engine off. Check your fuses and wiring to the solenoid.
