? for Procharger guys
Old 10-10-2007, 08:43 AM
Hawk108's Avatar
Default ? for Procharger guys
Ive searched, but could only find the answer for turbo guys. Im assuming that with a procharger you would also want a gear similiar to a 3.50, but wanted to confirm. So the question with a procharger would you want 4.11's or 3.50's? Thanks.
-Noah
Old 10-10-2007, 08:44 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Ive got 3.73's...
Old 10-10-2007, 09:37 AM
koji777's Avatar
3.73's here
Old 10-10-2007, 11:28 AM
Blownramair's Avatar
3.73s
Old 10-10-2007, 11:50 AM
E Wagz's Avatar
3.73's in a Strange S60
Old 10-10-2007, 12:01 PM
Hawk108's Avatar
okay so 3.73's are a good gear. . . . .are 4.11's BAD for prochargers?
Old 10-10-2007, 12:10 PM
ChevyChad's Avatar
If you mean 'bad' as in you'd probably have to shift into 5th at the drag strip, then yeah...
Old 10-10-2007, 12:16 PM
ss01layinwheel's Avatar
3.42's here
Old 10-10-2007, 12:21 PM
Hawk108's Avatar
Bad as in. . . .itd be a pain in the butt how much you would have to shift
Old 10-10-2007, 04:52 PM
Floader's Avatar
3.80's, but alot has to do with tire size
Old 10-10-2007, 04:56 PM
Scary Guy's Avatar
I use 3:70's with a 28" tire.
Old 10-10-2007, 05:27 PM
Hawk108's Avatar
alright guys thanks. . . .looks like 3.73's are a good choice for prochargers
Old 10-10-2007, 05:59 PM
Mark98SS's Avatar
Running a stock long block with cam & headers - 4:11s & a 28" tire mine trapped 126 at 6500 with the 6spd but went about 7000 at 126 on the TH400. I switched to 3:50 gears on the TH400 & am trapping at 126-128 at 6000 now & ETs have improved. I think a 3.73 for my set up might have worked a little better. If you don't have a cam or at least upgraded valve springs a 3.50 might be good.
Old 10-10-2007, 08:41 PM
CHRISPY's Avatar
Turbos are load dependent so taller gears (lower numerically) can help spool. SC'ers are belt driven so you can set it up like an NA car...gear it for the 1/4 mile with rpm at the traps about 300-600rpm past power peak (Depends on how the combo holds power after peak)
If its street driven and a six speed 3.73s are typically a good choice on 26 inch tall tires....
Old 10-10-2007, 08:46 PM
Speedy0009's Avatar
3.91's here with a D-1SC.... Mods in sig otherwise!
Oh and it's a GTO so the gears are from Austrailia... LoL
Old 10-10-2007, 10:32 PM
With 3.73s (DTS 12bolt) I run 142-145 @ 7000 at the traps... That's with a TH400 and a tite TCI converter... hope this helps....
J
Old 10-11-2007, 01:32 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
And another for 3.73 here. With my redline set at 6700 rpm. Leaves plenty of room for top speed runs.
Old 10-11-2007, 08:16 AM
ChevyChad's Avatar
J
Is that with 28" tires, or 26"? I would think 28, but just wondering...
Old 10-11-2007, 07:20 PM
Moz
Moz's Avatar
3:73's for me in a DTS 12 bolt 33spline's and a 28"tall tire.If you go with the 4:10's you will have traction issue's ALL DAY LONG.
Old 06-15-2008, 10:24 AM
gotmeone's Avatar
Hey i was woundering what is SDCE 8 Rib?
Quick Reply: ? for Procharger guys
