Wireing Question?? Don't Know What Forum To Ask In?
Location: where ever i can store my car. (palos hills,il for now)
Ok I Started To Do The Wire Mod And I Forgot To Mark One Of The White Wire On On Of The Conectors. One Is Not Used, I Looked It Up On Alldat A Nd It Looks Like It May Be Connector 105 And Pins F And G. Is There Any Way To Find Out Which Wire Goes Were So I Can Finish This Stupid Problem?? One Is Used And One Is Not, According To The Printout On Is The Cruise Control Indicator Lamp Output And The Other Is The Tach Signal. I Took Out My Cruse So I Don't Care If I Fix That, My Car Is Apart So I Cant Just See If The Tach Works, Is There Any Way To Check Continuity To The Tach Of Output Lamp.
Thanks For The Help,
Cliff
Cliff
Restricted User
Here are the pcm pin outs for a 2000
http://www.ls2.com/boggs/torques/00pinpcm.htm
C100 Plug
A PNK Hot in Run and Start (IGN/INJ Bank 1 15A)
B DK GRN/WHT PCM 43 A/C Clutch Relay Control
C DK GRN PCM 18 A/C Clutch Status
D GRY TPS +5v to TCS
E DK BLU TPS signal to TCS
G PNK Hot with IGN 1 Relay Engaged (Tranny/EGR 15A)
H DK BLU PCM 33 Cooling Fan 2 and 3 Relay Control
J DK GRN PCM 42 Cooling Fan 1 Relay Control
K BLK TPS sensor low to TCS
C101 Plug
A YEL/BLK Low Coolant Sensor
B PNK Hot in Run and Start (IGN/INJ Bank 2 15A)
C BRN PCM 36 Air Pump Relay Control
D DK GRN/WHT PCM 9 Fuel Pump Relay Control
E PNK/BLK PCM 19 Ignition Positive Voltage for PCM
G ORN PCM 57 Battery Positive Voltage for PCM
H BLK/WHT Ground
K GRY/BLK PCM 53 TCS Spark Retard Signal to Brake Control Module
C105 Plug
B PNK Hot with IGN 1 Relay Engaged (TCC Stop Lamp Switch/MAF/O2 20A)
D DK GRN PCM 37 Cruise Control Inhibit
F WHT PCM 13 Cruise Engaged Signal
G WHT PCM 10 Tach out to Brake Control Module
H PPL PCM 4 AIR Solenoid Relay Control
C100 Plug
C101 Plug
H BLK/WHT Ground
C105 Plug
