JL W7 10" and thunderform????
Simple here fellas will a 10w7 fit in the MTX 10" thunderform enclosure and is a MTX AUDIO TE1501D ELITE 1500W CLASS D for 389$ a good deal?
thanks in advance
thanks in advance
Don't use a W7; even if it fits (I'm not sure), there's not enough airspace, and I'm not sure the thunderform will even hold up to the amount of weight of that W7.
Good point.......airspace.....sorry i have benn out of the car audio world for a while. ok change it up, most bang for the airspace in a thunderform, i MUST keep my t top area so what are my options?
Unfortuntaley, if you want to use the T-top area...you aren't going to be using the W7 unless you want to cut your passenger side, remove the spare, and get a custom fabbed stealth enclosure for that side because there is more room. You could always sell it and use a W6 or other comparable sub. Then you could run a stealth enclosure and keep your T-top area.
personally, i would match that box up with a JL Audio 10w3v3 (4-ohm), and get an amp that pushes about 300w - 400w into a single channel (or two channels, bridged) to power it.
I run a pair of RE Audio SE10 in a stealth enclosures that do very well. The CDT EF-100 does great in them but has less excursion. I had the W3V2 D2 in the same enclosure. The CDT is a tighter sounding sub but both sound good. Both can be powered with 300watts rms efficiently. TC Sounds Epic Series 10" sub would work in a stealth as well but you'd need more amp..600w-750watts rms. There are several other options as well.
