10 Bolt For Sale
10 Bolt For Sale
I have a 10 bolt out of a 99 Camaro for sale. I bought this from a member here a while back for a spare but I dont think Im going to need it. It has a 3.73 GM Gearset, an auburn posi, and aftermarket axles (Im 95% sure they are moser). It has the backing plates but no calipers, or rotors, also the one axle does not have a reluctor ring (4 channel ABS)
The rear end worked fine and looks fine (it was checked out by Straightline before I bought it) but I guess the auburn posi made some clunking noises under hard accel? Maybe the previous ower will chime in I have done nothing to it, just store it, I paid $150 for it and id like to get what I paid. Im in orland park, let me know if you have any questions, thanks
Yep, I tihnk the center section may need some work or something, I guess it would clunk under hard accel, maybe its fine? I just dont want to say its fine when the last person I got it from said it clunked. I never heard it so I dont know. Im not sure if the gears would work with the center section you have or not. Im pretty sure they would.
Retired Street Racer
It is out of my car. The rear end would clunk if I made a tight turn, kinda like a spool on the street. I didn't have the time to open it up and check exactly what was wrong with it, so I put a stock 10 bolt back in my car. I drove with it making that noise and even took it to the track and made a few passes. It is probably the posi, which is an Auburn. They are covered under warranty, so all you would have to do is send it back to them and get another. For $150, it's not a bad deal. Hell the axles alone are worth that. And you could part out the rest and make money.
