two man bleeding
Old 10-12-2007, 03:35 PM
jdizzle's Avatar
Default two man bleeding
we bleed the clutch no more air is coming out, but the clutch is still really springy...its not giving resistance like it used to. what do i have to do?
Old 10-12-2007, 04:52 PM
purdueranger's Avatar
open, push, hold, close, repeat. I did this and the clutch has never felt better.
Old 10-13-2007, 09:30 AM
Gilbert@Ace Racing's Avatar
It can be very frustrating trying to bleed one of these systems. After we install new hydraulics or even open the system for a clutch install we bleed the system, let it sit for a couple of hours then do it again. Then we keep the car overnight to hit it one more time just to ensure that there is not going to be a problem... been bitten before with a very spongy pedal after a good test drive and delivering the car!
Stay with it and you'll get it. Call me today if you need some advice!
g
Old 10-13-2007, 10:41 AM
TheLS1Kid's Avatar
I always pump the pedal and hold, open bleeder, close bleeder, repeat.
Old 10-14-2007, 12:59 AM
OMGWTFBODY's Avatar
. worked here
Old 10-14-2007, 12:31 PM
studderin's Avatar
have the car level to, I think I get better pedle then a car with the front up only,on jack stands. Might ne BS, But I do it.
Old 10-14-2007, 12:34 PM
Black FormulaLs1's Avatar
i always bleed mine while it is up on the rack...PITA but i do it 2-3 times...smoke break..then another 2 times just to be safe....
Quick Reply: two man bleeding
