Grinding rear calipers
Restricted User
It took me about 30 minutes to do it, I used a air compressor and die grinder with an aluminum bit. I just kept spray painting the caliper with black paint, putting the wheel on with 2 lug nuts, spin the wheel a couple rotations, then took it off and kept grinding where the paint is rubbed off. Repeated this process about 5 or 6 times until the paint didnt get rubbed off. Then drive the car around and make turns and make sure the paint doesnt get scraped off because the wheels will deform some when driving. If it doesnt then your finished. Tim
Location: where ever i can store my car. (palos hills,il for now)
good luck i just used a grinder with a regular blad and it took for ever. i did not you paint i put grease on the calipers and spun them. works the same
