GTO weight??
Sept 5th I weighed in at 3932lbs full weight, half tank of fuel. Same day I took out everything in the trunk for one last pass (since I got booted for no cage) it then weighed 3862lbs.
I recently raced again and took out the passenger seats, emptied the trunk and took off the skid plate. Weighed the car at the local weigh station with skinnies up front and slick on the back ..... 3740lbs with about 5 gallons of fule in the tank according to the "alternate mode menu" on the dash!
All weights are with me in the car and are subject to change per scale used!
11.48 at 3862lbs
11.29 at 3740lbs
.....and still more in the car..... both to come out for weight and power to put to the ground! It's back to full weight and most likely will stay that way until another special occasion!
11.48 at 3862lbs
11.29 at 3740lbs
