sts help
Old 10-13-2007, 07:21 PM
trans2000am's Avatar
Default sts help
ok just got my car done finally now the car wont boost for nothing.
tell you guys what i got first
sts kit with intercooler from trt build forged motor and all with tune,42 pound injectors,walbro 255 fuel pump.
now when i get on the car i can hear the turbo spool up,but nothing happens no boost what so ever. look at the wastegate its not stuck open.
next day i installed the adjustable boost controller,followed instructions from sts to the tee. now is i turn the **** like alot and i mean alot the car will see like 1 to 1.5 pounds but not until like 6000 rpm what the f*ck is going on? the turbo is spooling up like at 2500rpms is that where i should start to see boost? im not a guru on turbo systems so anything will help out.looking for a quick fix dont wanna take it to a shop only got like 4 weeks left to drive it,plus dnt feel like dumpning more money into until next year.
thanks guys
Old 10-13-2007, 09:52 PM
02 z/28's Avatar
did u check for leaks.
Old 10-13-2007, 10:28 PM
NYSS Guy's Avatar
Where is your boost controller referencing for a boost signal? How do you know for sure you aren't getting boost (boost gauge, scanner)? What size spring do you have in the wastegate?
Also, when I first got my intercooler, I kept popping the charge pipe off whenever it boosted. Then it wouldn't boost since all of the air was just going out to atmosphere.
Old 10-13-2007, 11:51 PM
b00sted's Avatar
The BOV may not be stuck open, but are you sure it's getting a proper reference signal? If it's not, it'll open right when the turbo starts to spool.
Old 10-14-2007, 12:13 AM
OreoLt1's Avatar
Definately check your vacc. routing for the BOV and check up and down for leaks on both sides of the turbo to the motor. I had a decent size hole in my exhaust but it was still enough to to spool up the turbo but not create boost.
I would un-install the boost controller for the moment untill you get your boost issue fixed just so you know that you don't have another possible issue with another system.
Old 10-14-2007, 01:50 AM
Jammer's Avatar
Leaking somewhere! Boost is boost.. if motor gets it...you will feel it!
Old 10-14-2007, 09:28 AM
geeteego's Avatar
+11ty billion. I had the same thing happen. Motor was only seeing 1.5-2lbs of boost.
Tightened everything up and it saw 9psi...big diff.
Old 10-14-2007, 12:17 PM
boost controller is from sts hooked it up per the instructions,have a boost gauge hooked up (have a reference block where the BOV,and boost gauge vac lines goes. as far as spring never checked that ordered the 5 pound spring for it when i got the kit.
last night my pipe that goes under the rear control arm blew off,is that signs that its getting boost but like to many leaks?
do you have pics of how you reference everything?cause per sts instructions they show no vac lines from the turbo nor wastegate going to any vac source
Old 10-14-2007, 12:18 PM
sorry for all the questions still new to turbo system but trying to learn
Old 10-14-2007, 04:56 PM
OreoLt1's Avatar
The wastegate gets it vacc. form the comp. side of the turbo. Make sure that the nipple on top of the wastegate is venting to atmosphere unless you have the boost controller installed. If it is installed you need to follow the install. pics to the T.
If you hooked everything up as the STS instructions stated you should be good. Make sure that your BOV vacc. source comes off a "T" from the brake booster.
If you blew off one of the pipes/couplers you definately need to check all of your couplers!
Old 10-14-2007, 10:29 PM
NYSS Guy's Avatar
If you have a 5 psi spring, and the reference is correct for the wastegate, I would think you have a leak somewhere.
Old 10-14-2007, 10:42 PM
gametech's Avatar
If you hook everything up according to sts instructions, you will probably only see about 3#'s off the wastegate spring, and this will flutter. You REALLY need to reference the wastegate from manifold boost, not the turbo. I am also confident that you have leaks somewhere.
Old 10-14-2007, 10:49 PM
WicketMike's Avatar
i had same problem.
My problem was that the pipe that goes over the axle had popped off and wasnt touching the pipe it was suppose to be attached to. Its kinda hard to see also
Old 10-15-2007, 01:30 AM
rojows7's Avatar
+1 for popping off the the pipe that goes over the axle was scared as **** heard my turbo spool but no boost hooked it back up and all was fine
Old 10-15-2007, 08:07 AM
ok thanks alot guys gonna go buy better clamps today and recheck my exhaust for leaks
Old 02-26-2013, 01:55 PM
JoshuaGrooms83's Avatar
so hey, any of you tell me what the difference is between hooking up the wastegate from the compressor then the intake manifold? just wondering. how does it effect responsiveness?
and yes... i know... thread necromancer at work again lol
Quick Reply: sts help
