Transmission service port above linkage, safe for temp sender?
Old 10-13-2007, 07:22 PM
Javier97Z28's Avatar
Default Transmission service port above linkage, safe for temp sender?
Just want to make sure that sticking that long temp sender into my trans in this port pictured below (above the linkage selector) won't cause any problems.
Thanks in advance..
Old 10-13-2007, 09:12 PM
LS1Tech Sponsor
performabuilt's Avatar
It will not cause any problems its a presure port. Temps may read a bit higher than true average but it will work.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 10-13-2007, 11:19 PM
Thanks, it's setup and working
I've read about the possible higher temp readings. I plan to put a deeper truck pan later on and have a bung welded in
Old 10-14-2007, 10:30 PM
BubaGumpShrimp's Avatar
thats where mine is and it works fine.
