hit the rev limiter did u screw anything up??
Old 10-14-2007, 09:26 PM
1979transam's Avatar
Default hit the rev limiter did u screw anything up??
i floored my car last night from a dead stop and had it down in 1st gear and i hit the rev limiter in 1st and 2nd pretty hard. i dont hear a knocking in the motor and the car seems to be okay, but do u guys think i screwed anything up in the process?? hope not
need suggestions
Old 10-14-2007, 09:28 PM
cherryelky305's Avatar
I would hope thats what the limiter is for, to stop from doing damage to the motor.
Old 10-14-2007, 09:41 PM
skeels's Avatar
The rev limiter is there to protect you from damaging stuff. Unless you did a mechanical over-rev then you should be fine. (IE going from the top of third gear and instead of powershifting 4th you go into 2nd gear).
Old 10-14-2007, 09:48 PM
nprather's Avatar
i annilhate the revlimmiter all the time! ur fine
Old 10-14-2007, 09:57 PM
haha thanks alot for responding do quick. i was just parrannoyed about it i have been told it dont hurt LSX motors but i just wanted to make sure.
thanks alot guys
billy
Old 10-14-2007, 09:58 PM
ULTIMATEORANGESS's Avatar
ive hit mine numerous times. if you dont hear any noises and your car feels ok you should be fine.
Old 10-14-2007, 10:03 PM
GIVE EM' THE BIRD's Avatar
Thats what its there for.
Old 10-14-2007, 10:07 PM
Sunset'01Z's Avatar
no worries
Old 10-14-2007, 11:33 PM
IZRED's Avatar
You're worried about hurting your engine? If that's the case, we all need to stop going to the dragstrip, lmao. Nah man, your engine should be fine, cause you said you hit your limiter hard in 1st. and 2nd. and it's still running good, you're good to go. The 1 thing I always do after running my engine hard, is test drive it through the city n highway like if I was regularly driving it. I turn the radio off and listen to see if I hear anything or if it's running abnormal. Then when I get home, I check the oil. A lot of cars like eating a little oil when driven hard.
Old 10-14-2007, 11:36 PM
djsanchez2's Avatar
^^^ HAHAHA same here. I thought i was the only one who did that.
Nah you'll be fine. I've hit mine my fair share of times. No problems at all.
Old 10-14-2007, 11:51 PM
slick1851's Avatar
When you start making real power, and your on a street tire get used to kissing that rev limiter like its going out of style
Its there to protect you engine from over reving, so it does it job
Old 10-14-2007, 11:53 PM
slick1851's Avatar
thanks alot guys
billy
lets say you are shifting really fast and are going to shift into 4th but slam it into 1st, then thats going to be a problem there and maybe some bent pushrods or worse
But flooring and loosing traction and bouncing off the limiter is fine, miss shift any car and it could be bad
Old 10-15-2007, 12:05 AM
BigBenz's Avatar
Its when i know to shift
Old 10-15-2007, 03:56 AM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Thats what the rev limiters for. Your fine!
Old 10-15-2007, 11:25 AM
nprather's Avatar
dude you **** that **** is gonna blow up now!
Old 10-15-2007, 11:55 AM
kyles2000z's Avatar
lol its pretty much 100% IMPOSSIBLE to go to shift to 4th and accidentally hit 1st, they are in two completely different locations lol. sorry, had to say that but im sure he knows what ya mean.
135R
246
Old 10-15-2007, 05:56 PM
hndakilr's Avatar
Imo The Rev Limiter Is Just A Stock Shift Light (without The Light Of Course)
Old 10-15-2007, 09:16 PM
JohnnyC's Avatar
You will be fine - it's there for a reason as stated above.
Old 10-15-2007, 09:18 PM
cabech984's Avatar
Thats where all my damn oil goes!! I noticed it lasted longer my first 3 thousand miles I owned the car!
Old 10-17-2007, 09:33 PM
displacementdan's Avatar
need suggestions
dont worry ur motor like that
