Teflon tape?
Old 10-15-2007, 09:45 AM
Dbluegoat's Avatar
Default Teflon tape?
Good or bad for the oil feed into the turbo? I am getting a small seeping out of the fitting.....
I have blue loctite and teflon tape just trying to see what I should use
Finally got the ST80 put on
Old 10-15-2007, 10:53 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I have never been a fan of the tape. The ARP thread sealer( tefflon paste ) is not much more than the tape and you know that you will have a good seal.
Keith
Old 10-15-2007, 11:56 AM
camarols1's Avatar
I never use tape because it can get into the oil line and cause trouble.
Also, when you use the teflon paste it is nice to be able to adjust the
fitting a little without having to pull everthing apart and re-tape.
Old 10-15-2007, 01:24 PM
SSilverSSurfer's Avatar
+2 i like the GM liquid teflon. works awesome
Old 10-15-2007, 02:49 PM
cablebandit's Avatar
i use paste but if it wont seal (like my fuel rails) then i use tape...no probs...just have to use some common sense and not leave it hanging over an opening or something before connecting fittings
Old 10-15-2007, 08:25 PM
DeltaT's Avatar
I use the Permatex hi-temp paste. When I used to use the tape I would find bits of it in the oil, so I stopped using it.
Jim
Old 10-15-2007, 09:23 PM
Administrator
unit213's Avatar
Pipe dope...no teflon tape.
Old 10-17-2007, 05:10 AM
EPP
EPP's Avatar
Thumbs up
Yes, don't use the tape. Most hydraulic companies don't allow tape to be used for that very reason, they use pipe dope instead. Bob
Quick Reply: Teflon tape?
